US Valve Manufacturer Receives Box Furnace From L & L Special Furnaces
The XLE 244 is equipped with solid-state relays for fast, quite cycle times to offer good control. These are housed in a NEMA 1 control panel with single-point power connection. All required fusing and interconnections are included. The control system is driven by a Honeywell program control with an overtemperature control to prevent the furnace from overfiring. A digital round single-input chart recorder keeps accurate recordings of the furnace process temperature. The Kanthal Iron Aluminum Chrome coiled elements located on the sides, back and door are controlled in two zones for balancing of temperature gradients from top to bottom.”
