GM Enterprises Vacuum Furnace 48” X 48” X 60”-2Bar
Recently “The Monty Heat Treat News” added a vacuum furnace to our used equipment listings-a vacuum furnace which is relatively uncommon on the used market mainly because of its size 48″ X 48″ X 60″. While it is complete and ready to run it will certainly require work on the hot zone. Currently the asking price is set at $125,000 USD, however due to space limitations the vendor will now consider all offers. https://themonty.com/project/itemvf-393-gm-enterprises-vacuum-furnace-48-x-48-x-60-2bar/
GM Enterprises Model HVF-701 Vacuum Furnace. Manufactured 9/25/1990, Serial Number 1282. Currently installed but not in operation. Furnace is complete and in good condition however hot zone will need work. Work Zone:  48”H x 48”W x 60”L, load capacity 5,000 pounds. Max Temp: 2500 ºF. Operating Range: 10-5 – 10-6 Torr. Cooling:  2 bar pressure quench, 4400CFM.
