Lindberg Ships Pit Nitriding Furnace
"Lindberg/MPH announced the shipment of a gas fired nitriding pit furnace with built-in retort to the welding industry. This pit furnace is designed for single and two stage nitriding processes and post-oxidation applications. The design accepts either one-piece work baskets or retort baffle or nest trays. The gross load capacity is 5,000 lbs. at 1200°F and the furnace chamber has a diameter of 38” and is 90” tall. The furnace is designed to produce laminar air flow to obtain the required +/- 15°F temperature uniformity."
