Fire at a Heat Treat Leads to Furnace Auction
April 29th there will be an auction in San Antonio, Texas featuring some older vacuum furnaces, coating systems, machining centers and metal working equipment. The equipment is located at the “Meyer, MT, Texas” location, the site of a large fire August of 2025; “Massive fire near San Antonio Airport prompts second alarm response”
According to the auction notes, all of the equipment has been professionally cleaned since the fire.
While the furnaces are older models, vacuum furnaces generally sell at auction.
It is not clear whether this location is still in operation or not but it certainly appears that all of the equipment at this location is up for sale and this facility is no longer mentioned on the “Meyer” website.
About Meyer; “Meyer is a privately held, high-tech manufacturing company supplying a variety of precision components to the aerospace and gas turbine engine industries. The company began as Meyer Tool & Die in 1951, and has evolved over the years into an industry leader in turbine technologies, vertically integrated and offering all post casting processes as the trusted manufacturing partner. Meyer currently has over 1,400 electrical discharge machining (EDM) machines (wire, ram, and fast hole drilling). Meyer not only specializes in EDM, but also waterjet machining, conventional machining, abrasive grinding, laser machining and welding, EB welding, coating, airflow testing and other processes required to be the trusted manufacturing partner for airfoils and other hot section turbine components.”
