“The McCurdy Take”-A Heat Treat Horror Story
“The Monty Heat Treat News” is honored to be able to offer “The McCurdy Take”, a regular column from Mr. Dan McCurdy, an individual who has spent a lifetime in the heat treat industry. This column is entitled “A Heat Treat Horror Story” and we promise you will find it fascinating reading;
All heat treaters have stories about how something went wrong on the job. I have in my 50 years in the business accumulated my own unique collection of them. I could sort them in a number of ways, such as by depth of stupidity, by amount of time and/or money lost, or by degree of embarrassment experienced.
Some of the stories involve actual metallurgy, but if I am honest most are about situations where a degree in metallurgy was of zero help or even detrimental. It is absolutely true that they do not teach common sense in engineering school. The main theme running through this collection of stories is how we humans tend to invent all sorts of imaginary root-cause scenarios when presented with unexpected outcomes. Many of the most entertaining cases involve ill-fated attempts at rework when a material did not respond to initial heat treatment as expected.
After a failed surface hardness inspection, the first stop is the job card. What are these parts made of, and how did we process it? If the job card happens to say AISI 1045, and the parts are to be oil hardened and tempered, there is no need for further investigation. Case closed. Job-shop heat treaters see this all the time. I eventually developed a well-informed opinion that 1045 steel should be illegal (or should at least come with a warning label that this material may or may not work as expected). This steel, according to the science, ought to be pretty predictable. In actual experience, 1045 is like a clown waiting to pop out and ruin your day.
Part of being a steel heat treater is feeling bad about not successfully hardening a part that has been entrusted to you. Therefore, the first round of corrective actions involves demonstrating that the initial inspection must have been wrong. It is sometimes necessary to try every single hardness measurement method and tester in the building to prove this. Multiple people gather around, sometimes including the Plant Manager, in a competition to get two consecutive good hardness readings on the wayward part. In the end there are so many dimples on the part’s surface that it looks like it might have measles.
Having failed to establish that the messenger (i.e., the inspector) was wrong, the challenge is escalated and the plant’s underground rework machine gets fired up to make things right. It is an impressive arsenal, ready and able to gobble up as much time, energy, and manpower as it is allowed to. The options are many, starting with running the parts the same way again while hoping for a diferent result. (If this actually solves the problem, everyone should be left wondering what just happened, because this ‘solution’ must fail by definition if one really thinks about it.)
After a failed rework, however, it is time to tell the customer that there is a problem with their material selection. The customer’s response will be, of course, that they have been making this part out of the
same material from the same supplier for 10 years and there has never been a problem before. You think to yourself that of course there was no problem before, because last time around the heat treater went to extraordinary lengths to avoid making this call in the first place. It is all very circular.
Having reviewed the job and the results from the other parts that were processed along with it, the heat treater must conclude there was nothing done wrong and this is just another 1045 fiasco to deal with.
How about increasing the austenitizing temperature by 50° F and trying it again, this time with a longer soak, max oil agitation, and plenty of open space over, under, and around the parts, perhaps combined with a slightly enriched carbon potential in the atmosphere. Or better yet, don’t we have a faster oil in one of the furnaces? Let’s run it there. Or how about wiring the parts up and suspending them in the neutral salt bath and then water quenching them individually?
Eventually, one way or another, the parts manage to pass a surface hardness inspection and are returned to the customer in a condition that represents a sort of truce with the universe.
On the heat treat floor, the job is gone and forgotten. However, in the plant’s P&L there is now a $1,000 profit hole whose very existence is not detectable by any accountant, created by a $75 minimum order that may show up repeatedly over the coming years, requiring extra efort some or all of the time.
Meanwhile at the customer’s ofice, the AISI 4140 salesman in the lobby is told that his product is just too expensive, and that good old 1045 always works great.
Putting 1045 aside, the most dramatic rework fiasco I have experienced occurred early in my career, in fact while I was still a co-op student. I was working at a manufacturing plant that specialized in making extremely large parts for steel forging and rolling mills. Our captive heat treat shop featured huge gas-fired, endo-atmosphere retort pit furnaces designed to carburize and harden components up to up to 65” in diameter and up to 20 feet long, and 70,000 lbs. or more.
One day a huge 30,000 lb. mostly cylindrical component rolled in from the machine shop. It was not a gear or a roll; it was an oddly-shaped intermediate part of a forging power train in some Great Lakes mill. It was specified as AISI 4340 steel with the largest cross-section at 35” or so. We were to neutral harden it to a quite common spec range of 280-320 BHN. The part had been made with 2” threaded holes in one end to accommodate the water-cooled eyebolts that we would use to suspend such large parts in one of our pit furnaces.
The part was lowered into the furnace and the cycle commenced. Because of the thick cross-section involved, the hardening cycle took nearly 2 days and was finished with a crane-assisted open-air oil quench (always spectacular with these sorts of components, good thing the roof was so high).
After the part had cooled in the fast oil (9 seconds on the old GM scale) for several hours, we pulled it out, let it drip a good long time, and transferred it to a waiting deep pit temper furnace at a conservative 900°F.
As-quenched hardness testing was not performed on parts like this for practical reasons. In fact, getting such large parts into tempering was always considered an urgent task. The temper went on for two days before the part was removed and laid down on the floor to cool before inspection. This inspection took place the next day with the part still warm to the touch. Multiple readings were taken, all of them around BHN 240, equivalent to Rc 23, almost dead soft.
Our initial reaction was that the part had obviously not been made of 4340 steel. We went to purchasing with this suspicion and they came back later in the day to inform us that there was absolutely no way the part was not 4340 steel. We then did some chemical nickel spot testing, and the presence of substantial nickel content was indicated which supported that the part was 4340. We also did some old-fashioned spark testing that seemed to show that the steel was neither low-carbon nor high-carbon; it was in between, which supported 4340 as well.
I started to wonder if it was even possible to harden a part of this material in this huge cross-section in oil. I had not seen it done on such a thick part. I was assured by my colleagues that it had been done many times before in the shop on even larger parts.
The decision was made to re-harden the part and drop the first temper temperature to the absolute minimum, which was around 250°F, so we could get an as-quenched hardness reading this time.
It took another week to get the part re-hardened and inspected, and the result was exactly the same.
More discussions were had amongst the company’s metallurgical brain trust. There were at least six degreed metallurgists employed at the company at the time, and all of them agreed that it was time to get this over with one way or another.
A third heat treatment cycle was ordered, this time with a water quench, which was the only other quench option. The plant sat right over a well that produced crystal clear ground water at 50°F on demand. This water was pumped through the huge water quench tank in huge volumes, seemingly endlessly.
The water quench event was attended by a number of the managers and metallurgists in the company, all anxiously awaiting the resolution of the mystery. The part was finally pulled out of the water after an hour or so, still warm, and sat upright on the shop floor.
As everyone gathered around, we began to notice that the there was a strange pattern all around the part that we had never seen before, like a black spider web. It quickly became apparent that the part’s surface was cracked – EVERYWHERE.
Impact Hardness was around BHN 550, equivalent to Rc 54. The part was obviously 4340 all along and the cracks were no mystery after the water quench.
All heads FINALLY turned slowly to the temper furnace we had been using all along. It was impossible to see into the furnace from where we were standing, but the controlling instrument said it was running at 250°F. This furnace was part of a row of such pit temper furnaces. The control instruments were 75’ away in a control room (except for the overtemps, which were in the furnace electrical panels down in the pit nearby, where no one ever routinely went).
By the next morning, we all knew that the forced air single-zone temper furnace was running about 1000°F hotter than the setpoint. Both type K thermocouples (control and over-temp, in the same well) were totally shot. These were heavy gauge type K hand-welded thermocouples with square cross-section wires 1/8” thick as I recall. They had obviously been in place for a very long time (i.e., years). Up until that point, I knew how thermocouples worked but I did not REALLY understand that their assured accuracy and reliability were quite finite (months as opposed to years or in this case, decades).
I was the local representative of the metallurgy department when this fiasco blossomed, and I quickly learned what it was like to be sitting in the dead center of a blast crater. Fortunately for me, my older and more experienced colleagues had all fallen under the same spell I had. Or I was so persuasive that I managed to mislead every one of them all by myself; I will never know.
Organizationally, the metallurgical people were not part of the heat treating department. They were part of a separate and distinct metallurgy department, with heat treatment advisory being one of the department’s functions. Pyrometry was nominally the responsibility of the electricians in the company’s central maintenance department. Replacing a thermocouple was like changing a light bulb to them.
Actual calibration and repair of the instruments was outsourced by the maintenance department to a contractor whom I had seen just a couple of times in the plant over my tenure. This guy looked after the instruments, but not the thermocouples. It turned out that NO ONE was looking after the thermocouples.
This all happened in 1976. SAE International did not issue the first version of AMS 2750 until April 1980. Up until that point, it was common in the industry to run thermocouples until they either failed altogether, or someone smelled a rat. Making it even more dificult were the instruments that the thermocouples were connected to in those days. We are talking about vacuum tubes and point-to-point hand-soldered electronics where even a simple resistor was the size of a grape. The outside instrument technicians had to bring their own water-ice bath with them to ensure zero calibration based on a real-life cold junction.
Today we are all well-aware of the potential issues with pyrometry practice and are accustomed to seeing temperatures in our furnaces to a resolution of 1°F on digital displays. Back then the best resolution you could hope for was maybe +/- 15°F and that was pushing it on a 0-2000°F analog scale that was 6-12” wide. The resolution was limited by the accuracy of the paint job on that sheet-metal scale.
So, there you have it, a true example of a heat treatment fiasco wreaking havoc on a company’s P&L. None of us individually were at fault but at the same time we all felt like absolute idiots.
The company ordered another forging and a few months later the replacement sailed through the heat treat department in record time and hit the dead center of the hardness spec. I lived to fight another day, a bit older, but also a bit wiser.
Incidentally, the company’s Quality Manager at the time was himself a metallurgist but all he was interested in was which department would be forced to accept the scrap and rework costs. As one might imagine, there was quite a battle between the metallurgy and heat treat departments on that. My own view at the time was that it should have been an even split among three departments: heat treating, metallurgy, and maintenance. Thinking back now, it should have been 5-way, including the quality department itself and executive management for failing to run the company in a rational way that considered the actual risk environment. No such thing as ISO 9000 in those days, let alone entrenched concepts of preventative maintenance and quality manuals and quality audits and proper written work instructions. Today, that scrap ticket would easily go 100% to the Quality Department for failing to have even a quality plan or policy. The manufacturing world has certainly evolved for the better over time!
