Furnace Controls Upgrade-“The Monty” Provides the Background
“AUGUST 2, 2026The AICHELIN dual-chamber continuous furnace at SEW-EURODRIVE Germany has been operating reliably in continuous service for many years. Regular maintenance and targeted modernization measures by AICHELIN Service GmbH ensure that the system always remains at the cutting edge of technology.
The overall facility covers many acres, the heat treat department is relatively new-the furnaces you see below are approximately 10 years old were built and installed by Aichelin. What you see are multi chamber batch furnaces with oil quenching designed for case hardening of gears and shafts along with washers, tempers, charge cars, shotblasting equipment and a very complete lab-in short everything required to run a state of the art heat treating department. Even a cursory glance at these pictures will show you that this is a meticulously maintained heat treat which is very much in line with the whole plant. While this installation is fairly typical of the heat treat department of a major gear manufacturer we will also say that this is a finer example than many. May 18, 2020″
