European Service Provider to Add Second “HIP” Unit
“ OWL GmbH” of Germany a provider of “Hot Isostatic Pressing” Services” (Hipping) will be adding a second Hip unit. The new system will have working dimensions of 500 mm (Diameter) X 1500 mm high. Max. Temp will be1350 degrees C with a maximum pressure of 140 MPa and will be NADCAP ready. This system will be operational by the end of 2027. This photo shows the first installed system;
Why another HIP machine?
• Meet growing demand
• Ensure the highest quality standards
• Drive technological development
• Strengthen competitiveness
• Achieve (even) faster turnaround times
• NADCAP qualification for the aerospace industry
“About OWL GmbH;  We are your HIP – Hot Isostatic Pressing service provider. Hot isostatic pressing (HIP) is a manufacturing process that eliminates the porosity of metals and increases the density of many materials. This improves the material’s mechanical properties (fatigue strength, ductility, impact resistance) and machinability; in other words, the component’s reliability is significantly enhanced by the HIP process.
When components are treated with the HIP process, internal cavities and micro-porosities are eliminated through a combination of plastic deformation, flow, and diffusion bonding of the material by simultaneously applying heat and pressure.
The HIP process is used to significantly improve the technical properties of, for example, cast products, additively manufactured products, tools, motorsport components, and aerospace components.”
