Wisconsin Oven Ships Two Conveyor Ovens
“Wisconsin Oven is pleased to announce the shipment of two (2) natural gas, in-direct fire, two zone conveyor ovens. These ovens will be used in the manufacturing process of electric utility equipment. The maximum operating temperature of the oven is 325° F and has a minimum operating temperature at 60° F. There are two work zone chambers the first chamber has dimensions of 35’0″ wide x 6’4″ long x 4’2″ high. The second camber has work dimensions of 35’0″ wide x 12’4″ long x 4’2″ high. These ovens can heat 10,240 of composite materials.
“These two zone conveyor ovens are identical. They are equipped with Wisconsin Oven Corporation’s patented high efficiency Expandable Surface™ design. They will be used to heat composite materials that will be used in the manufacturing process of electrical utility equipment.” – Tom Trueman, Senior Application Engineer.”
