NASA Moon to Mars Mission Part 2 By David Pye
We continue the discussion the Part 2 presentation of this epic journey. Now the United States of America with NSA are now really planning the ultimate Lewis and Clarke experience by opening up the passage/route/journey to our nearest interplanetary neighbour, which is that of Mars.
How will the journey to be undertaken to from Moon to Mars?
The first portion of the journey will be undertaken by making use of current material science technology for the selection of the Moon vehicle. This would most likely be constructed from conventional materials with newly developed materials and thermally strengthened in some manner, either by
- Surface Heat Treatment (carburizing, nitriding, thin film hard coat, Carbon Reinforced Carbon Materials)
- Material specification determinations
- Mechanical property requirements
- How to accomplish the required mechanical properties
- Establishment of repeatable thermal processing conditions and standard operating procedures
- Authoritative Body to establish accurate processing conditions
- Authoritative Body to establish process auditing
- Frequency of audit establishment
The above are just a few suggestions of the establishment of repeatable heat treatment.
Moon Base Construction
Knowing the likelihood of failure improves the likelihood of success. The more data that can be acquired and accurately calculated, analysed and understood, the success of the mission improves significantly. They need;
- Workshop to assemble the Orion command vehicle.
- Material used during the command module erection procedure.
- Earth moving equipment
- Deep hole drilling
- Food
- Workshop with fabrication facilities, and repair facilities for the site erection.
- Maintenance of rover vehicle
Materials and Moon Base Establishment
- Astronaut suit maintenance and servicing
- Patching material for the construction protection against micro meteor strikes
- (Critical) the vehicle’s engine, the type of engine, the fuel for the various inflight conditions that the command vehicle will experience during its outbound and return journey back to the Moon Base
The absolute first consideration must be to set up a moon base with an area that the vehicular transport of the Mission to mars can be assembled. It is quite surprizing to see the almost replicated geometric design of Orion in relation to the early Apollo missions. The command module design has almost become a ‘design feature’ of ‘proven design’ with a much-improved communication and navigational systems.
Planning the Journey
In order to start the planning of the mission journey, the knowing and understanding of the potential likelihood of failure will most certainly improve the strong probability of the mission success.
Courtesy Lockheed Martin. Impression of the Mars Mission Vehicle
Apollo Command Module Construction Illustration for earth to moon to establish a Command Centre Lunar base. (Courtesy NASA and Lockheed Martin) of the opinion that it will necessitate a number of missions from earth to the moon, to both build a moon base, as well as carrying the mission vehicle components to the assembly base, to assemble the vehicle that will make the journey to Mars. The architecture for Moon Base 1 will be unlike any architectural structure that has ever been designed or built here on the planet Earth. In itself, it will be an architectural wonder, designed by man!!
Command Module Cross Sectional View (Courtesy NASA and Lockheed Martin)
To assemble the vehicle that will make the journey to Mars. The architecture for Moon Base 1 (named for the purpose of this article), will be unlike any architectural structure that has ever been designed or built here on the planet Earth. An architectural wonder, designed by man!!!
A suggested type of Low-Pressure Residence and command post. Courtesy NASA
The site for the Mars Vehicle Moon Base 1 would have to be chosen with great care, with the primary concern being to ensure a construction site as flat as possible and of a large enough size as to allow both constructions of Moon Base 1 and the assembly and launch pad for the mars mission vehicle.
An artist’s impression of Moon Base 1 under construction (Courtesy NASA)
I envisage that the assembly ship carrier that would carry the construction material for Moon Base 1 would not be unlike the well-known and proven vehicle design of the space shuttle, possibly larger. The construction tools materials and construction crew could be put down onto the moon surface utilizing one of the following methods;
- The Moon component delivery vehicle with a lunar landing module, (Not unlike the proven design of all of the manned moon walks and Rover vehicular carriers)
- A landing of the Space shuttle on wheels
- Or the Space shuttle on landing skids
- Or the Space shuttle fitted with retro rockets to make a controlled descent to the lunar surface
The Earth to Moon transportation vehicle would also need to incorporate a fuel tank system to enable the shuttle vehicle to lift off for the journey back to Earth for its next moon base material construction load.
The shuttle would not only be carrying the moon base construction materials but the construction crews themselves, as well as well as assembly tooling; that is drilling and earthmoving tooling or moon moving tooling, and sustenance for the assembly crew on the Moon Base 1.
The metallurgy involved in the assembly tooling, the construction materials, must be of the highest level of architectural design in relation to the material development and selection, thermal processing, heat treatment, that has ever been developed by man.
Lunar Surface Construction Methods
The first consideration for construction material would need to be the choice of suitable construction materials. Heat treaters and metallurgists know that no matter what type of steel is used, there is always potential for the formation of retained austenite. The low temperatures that the lunar environment can drop down to as low as approximately that of -225°F. Thus, any retained austenite present will decompose to untempered martensite and become massively brittle. There would also need to be consideration to the material temperature gradient between the lunar atmosphere and the internal vehicular assembly area.
So, could we consider aluminum alloys? Those of us who are familiar with heat treatable aluminum alloys are aware that in order to keep aluminum soft after solution treatment, cold treatment is utilized. Thus, with temperatures that can drop down to approximately -225°F, then the aluminum alloy will remain permanently soft and susceptible to micro meteorite penetration.
The next alternative may well be to go under the Lunar surface. That too has its problems!! Firstly, if blasting is considered, to go subterranean, because of the low gravitation conditions, the detonation would most likely create a long-term dust storm. If subterranean drilling is considered, the drill bits as we presently know them would not function too well. This would be because;
- A massive temperature rise caused by frictional forces at the cutting face of the drill, due to the lack of air (no air).
- Extreme low lunar atmospheric pressure will also make a contribution to the potential of the drill bit to overheat.
- The drilling debris is generally flushed away on earth when deep hole drilling, by flushing with water!! (no water on the Lunar surface)
- The protection required for the construction crew to be protected from the serious potential from cosmic ray penetration.
- Once the lunar surface has been prepared for construction, and the construction of Moon Base 1 is constructed, then there will be the need to consider the internal assembly area and the creation of the living and working environment. The site will require insulation to ensure a comfortable habitable working and living environment.
- A significant advantage of Moon Base 1 would be the generation of electrical power, which could be acquired from Solar Energy due to the log daylight hours and no cloud coverage of the lunar surface
I believe that this is THE project that will make America truly, great again, and to lead the world in interplanetary flight open new routes to the stars, and may it continue with the same vision that Lewis and Clarke in opening a new route to the North West Pacific Coast. Going where no man has gone before, is now becoming a true and visible reality!!! (Courtesy Star Trek The Last Frontier)
