Gasbarre Thermal Processing Systems Receives Orders for Three Batch Steam Treaters
Gasbarre Thermal Processing Systems recently received three separate orders for batch steam treating equipment. The batch steam treaters produce an oxide layer that promotes corrosion and wear resistance properties and provides an attractive surface finish. The three unique orders range in size from 18” to 30” in diameter and 12” to 48” deep. The gross load weight capacity ranges from 300lbs to 1800lbs with Gasbarre supplying the production tooling. The equipment is electrically heated and has a maximum operating temperature rating of 1400℉. Steam treating processes are used in many different industries. As such, these orders will be shipped to companies that provide products to the medical, additive manufacturing, automotive and consumer products industries.
With locations in Plymouth, MI, Cranston, RI and St. Mary’s PA Gasbarre Thermal Processing Systems has been designing, manufacturing, and servicing a full line of industrial thermal processing equipment for nearly 50 years. Gasbarre’s product offering includes both batch and continuous heat processing equipment and specializes in Temper, Tip Up, Mesh Belt, Box, Car Bottom, Pit, and Vacuum Furnaces as well as a full line of replacement parts and auxiliary equipment which consists of atmosphere generators, quench tanks, and charge cars. Gasbarre’s equipment is designed for your process by experienced engineers and metallurgists that understand your requirements.
For more information on how Gasbarre Thermal Processing Systems can manufacture custom-engineered heat treating equipment solutions for your specific thermal heating requirements, contact Bill Gasbarre at (814) 590-6282 or via email at [email protected]. You can also visit our website at www.gasbarre.com and find us on LinkedIn (Gasbarre Products Inc.), Twitter (@gasproinc), and Facebook (Gasbarre Products Inc.).
