Gasbarre Thermal Processing Systems Commissions Integral Quench Furnace Line
Gasbarre Thermal Processing Systems is pleased to announce the commissioning of an integral quench furnace line to a supplier of specialty nut and bolt assemblies in the eastern United States. The furnace line includes an integral quench furnace, parts washer, temper, and associated material handling and load storage. The system is designed to process 24” wide x 24” long x 20” tall loads weighing up to 1,500 pounds. The system includes custom designed material handing to eliminate the need for expensive cast base trays. Gasbarre was selected as the equipment provider based on their ability to provide a custom solution for the customer’s thermal processing needs, including special material handling, and fire suppression in the oil quench tank. Gasbarre’s design also enables the customer to increase their load size, allowing for higher throughput per load.
With locations in Livonia, MI, Cranston, RI, and St. Marys, PA, Gasbarre Thermal Processing Systems has been designing, manufacturing, and servicing a full line of industrial thermal processing equipment for nearly 50 years. Gasbarre’s equipment is designed for your process by experienced engineers and metallurgists that understand your requirements.
