Gallos Metal Solutions Completes Installation of 4th Mesh Belt Furnace Line
Further down you will find a press release from September of 2020 about how Gallos Metal Solutions in Milwaukee, WI, USA had accepted a brand new 4,000 pound per hour mesh belt furnace line from Can Eng International. The line is now installed as can be seen in these photos and we have these further details; “James Gallos – Owner of Gallos Metal Solutions Inc, of Milwaukee, WI stands with Can-Eng Field Engineer Gabe Bylsma in front of Gallos’ newest addition- a Can-Eng 4000 lb/hr high capacity Mesh Belt Furnace System. This furnace system was custom designed to provide optimal throughput when running parts requiring carbon diffusion and lighter belt loads. Gallos Metal Solutions Inc. currently operates four Can-Eng Mesh Belt Furnaces that are used primarily for demanding processing including Carbonitriding and Carburizing.”
“SEPTEMBER 2020 NEWS RELEASE; Can-Eng Furnaces International, Ltd. (CAN-ENG) has recently delivered a high capacity Mesh Belt Heat Treatment Furnace line to Gallos Metal Solutions Inc., Milwaukee, WI (GALLOS).
Specializing in continuous mesh belt atmosphere heat treatment, GALLOS selected CAN-ENG to provide a custom engineered continuous atmosphere heat treating system to be used primarily for demanding processing including Carbonitriding and Carburizing, while allowing for neutral heat treatment with a production capacity up to 4000 lb/hr. This furnace line is part of GALLOS’ massive plant expansion and modernization project which has more than doubled the existing plant square footage, increased capacity and added automation. Can-Eng’s highly engineered and custom system allows for an increase in usable hearth area to provide high-volume processing when running products requiring carbon diffusion and lighter belt loading.
This new capacity addition features: a computerized controlled automated bin dumping and vibratory part feeder system, dunk and spray pre-washer, protective atmosphere controlled mesh belt hardening system, oil quench, dunk and spray post wash system, forced recirculation temper furnace, in-line post cooling system, and CAN-ENG’s PETTM Level 2 SCADA system. By integrating CAN-ENG’s Level 2 Automation, GALLOS provides access to vital tracking of products’ status, detailed process data for continuous process improvements, comprehensive equipment diagnostics, cost analysis, and inventory management. This project marks the fourth Can-Eng Mesh Belt furnace line to be in operation at this facility.”
