Commercial Heat Treater In Midwest USA Adds 4,000 lb/hr Mesh Belt Furnace
These custom engineered continuous atmosphere heat treating systems feature an increase in usable hearth area to provide high-volume processing when running products requiring carbon diffusion and lighter belt loading, as they will be used primarily for processing including Carbonitriding and Carburizing. The furnaces are capable of a maximum throughput capacity of up to 4000 lb/hr neutral hardening each.
Both furnace lines reportedly feature; a computerized controlled automated bin dumping and vibratory part feeder system, dunk and spray pre-washer, protective atmosphere-controlled mesh belt hardening system, oil quench, dunk and spray post wash system, forced recirculation temper furnace, in-line post cooling system, and CAN-ENG’s PETTM Level 2 SCADA system. By integrating CAN-ENG’s Level 2 Automation, the end user also has access to tracking of products’ status, detailed process data for continuous process improvements, comprehensive equipment diagnostics, cost analysis, and inventory management which is required by many demanding customers.”
