Carburizing of Large Gears / Haerterei Reese-Our Most Recent Advertiser
105,000 gallon quench tank. Julian & Philip Reese
Reese has 300 employees in 4 locations, the headquarters is in Bochum, Germany (which “The Monty” visited) with two facilities in eastern Germany largely involved in the auto industry and a fourth plant in southern Germany catering to the tool and die industry.
The centerpiece of the gear heat treatment department is a gas fired pit furnace with working dimensions of 5 meters in diameter and 5.5 meters deep (approximately 15’ X 16.5’ deep), working in conjunction with this system is a 400,000 litre quench tank 21’ in diameter and 21’ deep and pit temper units. Weight capacity is over 100,000 pounds. While this is the largest furnace Reese also has other pit furnaces capable of handling shafts up to 18’ long.
While the Bochum plant is best known for the size of their pit furnaces their induction heat treat is comparably impressive and able to handle shafts up to 11 meters (33’) in length. Currently the company is investing in a brand new Induction facility which will be located in a new adjacent building, when finished in 2 years this will be in total a 20 million Euro investment. Also in the works is a new induction facility in eastern Germany slated for January of 2025.
These photos don’t really do justice to the size of the pit carburizing facility but they at least give you an idea about how very large gears are heat treated.
Gord Montgomery, Julian & Philip Reese, Jordan Montgomery
