Can-Eng Furnaces International, Ltd. and Roller Hearth Furnaces
“CAN-ENG Furnaces International, Ltd. is engaged in providing three separate systems amounting to over 450 feet of roller hearth furnace capacity.
The first of the three undertakings is a high capacity, roller hearth lamination annealing system. Produced for the transformer manufacturing industry, it will be supplied to one of North America’s largest transformer core manufacturers with operations in the USA, Canada, Mexico and China. The lamination annealing process is applied to transformer cores to enhance their magnetic properties and reduce core loss, ultimately improving efficiency and performance. The system integrates a pre-heat system, high temperature annealing furnace with integrated protected atmosphere-controlled cooling and accelerated cooling chamber. It is more than 300ft long and is capable of producing over 14,000 lbs/hr of atmosphere protected electrical steel core laminations used to manufacture high voltage transformer stations needed in the development of North America’s electrical distribution infrastructure.
“This project is being carried out largely to satisfy the demand for improving America’s aging and overburden power distribution network. As part of improving the nation’s power distribution network, consideration is being made to increase access to electric vehicle charging stations of which transformer cores are a critical part,” shared Tim Donofrio, Vice President of Sales, Can-Eng Furnaces International, Ltd.The second endeavor is a roller hearth solution treatment furnace system for a tier one supplier of cast aluminum automotive components. The furnace will be used as part of a continuous T-6 heat treatment system for the manufacturing of cast aluminum, safety critical suspension components, and will serve to supply for one of America’s largest Japanese-based automotive manufacturers. These suspension components are to be integrated into future hybrid and electric automobiles produced in America by the manufacturer.
The third project is a roller hearth atmosphere mesh belt furnace system for a tier one supplier of safety critical, high value fasteners. This system is used to atmosphere, quench and temper high value, safety critical fasteners used in automotive manufacturing. The system is rated for processing over 6000 lbs/hr, and is being supplied to an existing customer with four similar roller hearth furnaces. The system supports the ongoing demands for domestic-supplied, high volume, heat treatment capacity.”
