Home HEAT TREAT
NEWS
Used
Equipment
Business
Opportunities
Are you looking
for a career?
Advertise
with us
New
Equipment
Want to sell your
Heat Treat Shop?
Want to buy a
Heat Treat Shop?
ARTICLES: Cryogenic Treatments
FACTS
1. Cryogenic treatment transforms retained austenite to martensite, which increases hardness. • This may or may not increase wear resistance depending on the application. Retained austenite adds toughness to the structure, which enhances impact and fatigue resistance, both of which are important properties in many types of wear applications. Tough / ductile austenite inhibits crack initiation and blunts crack propagation. But increased hardness or "deformation resistance" resulting from cryogenic treatment often does result in increased abrasive wear resistance for many applications.
2. Retained austenite can transform to martensite under strain-induced conditions. • This can lead to dimensional instability in processing or service because there is a volume increase associated with the phase change of austenite to martensite. The problem is particularly acute with grinding, where retained austenite and its propensity to result in grinding cracks is a major concern in the gear industry. Thus, cryogenic treatment to eliminate retained austenite is highly desirable to avoid strain-induced distortion of parts.
3. Cryogenic treatment will amplify distortion. • If distortion is present after quenching, cryogenic treatment will make it worse. This means that from a “cryogenic standpoint” marquenching or vacuum gas quenching are desirable because both tend to minimize quench distortion.
Metallurgical Thought-To-Be Truths
4. The martensite that transforms from retained austenite during cryogenic treatment is structurally different than the “bulk martensite”. • Tempering after cryogenic treatment initiates the preferential precipitation of fine eta carbides only in the martensite formed from retained austenite transformation. Only epsilon carbides are precipitated within the bulk martensite. • Eta carbides enhance wear resistance by adding strength and toughness to the martensitic matrix. Note the use of the word toughness; this is an important attribute used to describe retained austenite and its contribution to wear resistance in certain specific applications.
5. Interrupted cooling before complete transformation can “stabilize” retained austenite. • Stabilization reduces the ability of austenite to transform to martensite. Therefore, it is highly desirable to perform cryogenic treatment of steel as in integral part of the heat treatment cycle.
6. Carbide wear improvement due to changes at microvoids. • The results of one study showed that only abrasive wear resistance (not hardness or other typically measured mechanical property) was improved by cryogenic treatment. With cryogenically treated carbide, “plastic flow may take place at defects (microvoids-points of stress concentration) due to shrinkage on cooling which results in residual compressive stresses on the surface of the voids on return to room temperature. Such stress reduces the effectiveness of the defects in lowering the localized strength of the material and this situation should result in the reduction of abrasive wear”.
Most “Marketed” Benefit
7. Improved dimensional stability and service performance. • Gun barrels, automotive racing parts (including engine blocks and heads), intricate parts to be EDM and numerous others; including golf clubs and balls, report very satisfying results on dimensional stability and enhanced performance. • Musical instruments purport improved sound quality. • Try it…you may like it.
Overview Comment
8. Cryogenic treatment is primarily performed for dimensional stability and improved wear resistance. Wear resistance is very application specific, but significant improvement in wear resistance has been realized for certain applications using cryogenic treatment.
Don Jordan, Vice President / Corporate Metallurgist of Solar Atmospheres, Souderton, PA., USA
